What do you think about add effects like stroke, feather, glow, drop shadow? Almost like in Photoshop.
Sometimes if we have a panormamic projection we use PiP for live input, or movies at an event. I usually use layer above the background layer for this, give it a 100% opacity, scale down and position it to it's place. It would be nice if I can give the clip border some effects to make it more independent from the background.
I found the drop shadow effect what you guys made years ago but it is just work if I use the crop effect so it works only "inside" the clip border, not outside. I hope I can make myself clear, sorry if it is hardly understandable. I don't want to use this effects for a loop with alpha, I would like to use all the pixels of the video content just add these effects to it's border.
Would it be difficult to add these features as effects?
thanks!
Stroke, feather, glow, drop shadow for a clip
gabonacorp
Re: Stroke, feather, glow, drop shadow for a clip
You can use the Drop Shadow effect for this, just reverse the order of effects and transformations: https://resolume.com/manual/en/r4/effects#render_order
That way the drop shadow will appear 'outside' your scaled clip.
gabonacorp
Thanks Joris, i tried it and it works! I am always impressed how many small details "hidden" in this amazing software.
thanks again!
thanks again!
