Resolume vs Yosemite
Hello guys, did anyone tried resolume IN osx Yosemite? How was it?
ReggieUnderground
Re: Resolume vs Yosemite
It has worked since day one with the first developer preview. Performance seemed normal but I didn't get crazy with the testing. If there's anything we learned from Mavericks it's to wait a while before upgrading.
Yeah i know that, i was just curious, about that, but i would like to know not from the user prespective but from resolume team prespective...
We've been using Resolume on Yosemite to make the recordings for the footage promos since the first dev version came out.
Do they look good enough for you to run a show with?
well... Ok! Seems that my concerns about the Yosemite issue was kinda overated! Thanks anyway...
- gpvillamil
Now that Yosemite is out, it would be awesome if Resolume could display its window title bar in black when Dark Mode is enabled!
Or implement fullscreen mode for Resolume.
joshuadmello
Any idea if DXV's can be previewed in finder now?
No it cannot and the standard QT app can't open them either.
I have to use QT7 to open DXV files. And you can't preview even if you change the default app to QT7.
I updated Yosemite pretty fast after release on my macbook, but not on my MacPro, since I usually use the first mostly private and the latter primarily professional (I'm a very occasional VJ, primarily editor/animator). But of course, only days after updating I was asked to do a VJ gig, so I had to do it with Yosemite. While testing, everything was fine, but after hooking up in the club, things started to run laggish. The video output (Mini display port > VGA) didn't work at all at first (I had to turn the resolution WAY down). and mixing went kinda well, but every time I added a 4th layer, the program crashed! Luckily I used a lot of dark sequences which turned to black very often, so it wasn't very visible that it crashed during the show, but it was pretty annoying.
I reinstalled Mavericks, and everything runs fine again. hope Resolume will come with an update very soon.
Could you contact us with your logfile, Pepijn?
