Now I created this 2:1 surface with two XGA beamers (2048x768). I have set things up with softedge and the testcard is looking good. But now I can't seem to figure out how to use my composition in a way that things are scaled correctly
After configuring up the mapping with a full resolution composition, do I then also switch my composition from 1920x1080 to 2048x768? How do I scale the content? Do I need to adjust each layer?
The only way I found is to enable the width and height in the layer and changing those values, but I'm not sure what I'm doing is the correct approach.
Can someone please enlighten me?
