I want to use Resolume to run one [maybe two if i can split the output from a laptop] small projectors just small ones that ppl have in their home not a large one's that ppl have in their homes small
So what pc resources get used most is it CPU or GPU RAM ?
i've tryed a few simple things using resolume on a dual core 3GHZ with an old 8800GTX and that seemed to work ok on a monitor
 would splitting the VGA out and using two small projectors increase the load if so what ?
 would splitting the VGA out and using two small projectors increase the load if so what ?cheer's
