Ableton live midi mapping to Arena problem
mad es
Post by mad es »
Hi!
I've spent hours and hours on this and Resolume still does not recieve midi input from Ableton.
Both computers show connection but when i run the midi track from ableton and try to map
in composition midi mapping mode in resolume - nothing happens. Getting crazy and having a big show
this weekend.
- ableton and resolume are running on IAC
- ableton runs a midi track with notes and sends out the midi signal
- both macs are connected through ethernet cable
- resolume iac is set to recieve midi
A solution would be soooo appreciated!!!
drazkers
Re: Ableton live midi mapping to Arena problem
Post by drazkers »
IAC is for the same computer, its like a bridge between programs. You need to setup a network midi session with IAC.
http://bit.ly/1neTMuZ or https://www.ableton.com/answers/how-can ... m-together
