Duration is incorrect one re-linked clips
voskull
Post by voskull »
Hi after looking into the NYE autopilot countdown clock posted earlier I found this "bug"
When loading a composition with custom clips duration, the duration showed in the clip panel is the default one and not the actual clip duration ( which can be seen by reading the .avc file )
This seems to only apply:
-> if the footage is relinked when composition is opened.
OSx 10.8 / Resolume Arena 4.1.11
ReggieUnderground
Re: Duration is incorrect one re-linked clips
Post by ReggieUnderground »
I've had clips set to BPM transport default to 1 beat after re-linking. Just did a quick test in 4.1.11 and it re-linked fine though.
If I remember correctly it was on comps I hadn't opened in a while like in your case. I'll follow up if I encounter the issue again.
Thanks for the find, Voskull. Should be an easy fix...
