Hello...
I got a question to do..
I got 2 Projectors running on Resolume (2 different Walls)
Projector 1: Runs Composition (1,2,3 Layers = Background, Footage , Masks)
Projector 2: Runs a Slice With 1 Layer atm ( Only runs Club and sponsors logo's..)
But on projector 2 i want to do something more... like 1 Slice (2 layers) for Background + Logo's or Masks...
Is it possible?
Example:
http://i.imgur.com/JHsv2wq.png
Reggards
How to Play various layers in 1 Slice...
Re: How to Play various layers in 1 Slice...
It helps to think of slices as little parts of your composition, and not so much as containers for content.
So the easiest way to achieve what you want:
- Make your comp twice as wide
- Position content you want to go on Screen 1 on the left, content for Screen should go on the right.
- You can use the Layer Widht, Height, Position and Scale params to position layers accurately.
- In the Advanced Output, use one slice to route the left half of your comp to Screen 1, and one other slice to route the right half to Screen 2.
