Hello Resolumes,
just ran into this small issue - perhaps its just on my system.
Comp Size: 2605x1280px
When I apply a Blur vfx on a widescreen clip 2400x600px DXV 25fps it gets disabled instead of bluring it.
The blur vfx works fine on smaller clips.
Greetings
Blur vfx disables widescreen clips
Re: Blur vfx disables widescreen clips
OS? ALPHA? Composition size?
I just made a clip with dxv @ 25 and a composition size that matches with blur working.
I'm windows 7, no alpha, output was to a 1080p monitor tho(Possible difference).
Thanks for testing....we have the exact same setup.
have you tried replacing the blur FFGL from the plugin folder? I've had files go down on me randomly, usually making after effects not open.
you...mean...I should overcopy the blur fx with a copy of a Blur fx?
