Hi everybody,
I'm new here and this is my first post.
Maybe you guys can help me with me questions:
I want to use a Matrox DualHead with Arena on my MacBook Pro over Displayport.
What i wanted to know is if edge blending between these two screens on the DualHead is possible.
I then ask myself if it's possible that I also can control the playback of the videos over DMX (or much better over LAN!) from my Chamsys Light Board.
If yes, how exactly do i do this?
Thx in advance
Ted
Edge Blending with DualHead
Re: Edge Blending with DualHead
http://vimeo.com/72656604 for softedge blending
Also Arena allows art net via lan. Do you know how to setup artnet on your chamsys board?
Ted Hollister
Not exactly.
I know from a friend that they set it up on a Windows PC, but I'm not sure how it works on a Mac.
https://secure.chamsys.co.uk/tutorial for getting an understanding of patching and setting up you system.
Resolume has a built in dmx mapping that chamsys has a fixture for. You just gotta patch a fixture with the resolume personality.
You can also just use generic dimmers and manually map artnet in resolume like midi.
Ted Hollister
Ok, I'll try that.
Thank you!
Thank you!
