9 hd outputs possible on one pc?
sikanda
Post by sikanda »
does anybody know a grafic card combination which enables 9 full hd beamers via matroxtripleheads? does linking grafic card help?
pfelberg
Re: 9 hd outputs possible on one pc?
Post by pfelberg »
Hi. For a start, I as far as I know, a MTH2G cannot achieve full HD resolutions per display, no matter what your graphic card is. Period.
Sikanda, to get 9 independent HD outputs, I would use a GPU with four to five outputs (ideally a card like the NVIDIA 780 GTX that has 2 dual-link DVI outputs) and two datapath X4 units with 3840x2060 broken down in 4 @ 1920x1080 screens plus one of the other card's output.
Note that because of the dual link maximum data rate at 330 MHz, you'll be able to get 3840x2060 at 30 Mhz not 60 Mhz.
Pfelberg, the MTH2G does support 3 @ 1920x1080 resolution on some GPUs but not very many. It's best to check on their website to find out which GPU supports 3 @ 1920x1080.
