stream Resolume output on a Website
Light Projection
Post by Light Projection »
hey guys,
do you know if it is possible to stream the output on a Homepage? We're going to project something on a big event and want to make it possible for everyone who is not there to watch it on the homepage.
Please help us! :-)
He2neg
Re: stream Resolume output on a Website
Post by He2neg »
The easy way is to seperate everything... so put up a camera in the back and stream this signal.
The other easy way is to Split your Signal behind your laptop and stream it then.
Streaming with the same Laptop you use to run Resolume i would not reccomend.
~Berlin~
It sounds like you need to set up a livestream. To do that you'll need to output your composition to both your projector and an H.264 encoder by creating two screens with identical slices) to send to the web using Livestream, Youtube Broadcast or any service you feel comfortable using.
Assuming you've got enough video outputs and some funds you can invest, a quick way to do it could output your web signal straight from Resolume using HDMI and broadcast using something like the Livestream Broadcaster: https://new.livestream.com/broadcaster.
dirtyjohn_lv
Post by dirtyjohn_lv »
Teradek works too, although a little more expensive
http://www.teradek.com/products/vidiu
Thanks for sharing DirtyJohn_LV. It looks like the Teradek is a nice unit that allows to broadcast to various platforms such as Ustream, Youtube Live and Livestream easily so that could be a great investment.
