Not loading movies...
nfms
Post by nfms »
I just installed win XP professional on another partition, made only for resolume, but with 2.0 it doesn't seem to load the movies.....
I can browse for them but when I drag em into a deck it doesnt load it...
version 1.51 does work...
anyone knows what can cause this ?
eeeedwin / bart ?
bryandod
decks may be your problem
Post by bryandod »
try deleting all of your decks or moving them out of the decks folder. if this doesn't work try deleting free frame effects. if i save more than a couple of decks, resolume will not load any clips. i can browse through the clips, but when i drag them over nothing happens. when this happens, no effects appear under the effects tab.
if i move the decks out of the decks folder, resolume works. it will even let me use those decks, but they do not work properly.
i hope this helps you
:o
Rincevent
Post by Rincevent »
I think he was talking about browsing files, not decks.
So my advice : double check you have the latest
-chipset driver (that was my problem on my Dell 9100)
-graphic card drivers
and maybe you need to install the indeo codec if you installed an XP SP2 (if i'm right they removed indeo at least in part in XP SP2)
nfms
Post by nfms »
thx
gonna try that,
it's SP2 indeed, i'll let you know if it works
nfms
Post by nfms »
not working :(
bryandod
Post by bryandod »
i know he was talking about browsing files. on my computer, if i save any decks when i reopen the program no files, or decks will load. all i can do is browse through the file , but not load them.
i have had currupt free-frames cause this same problem.
if you have any decks, move them and see if it works.
