RND transitions - I made a script that lets you select which
alex_d
Post by alex_d »
Hi guys, I asked about this a couple of days ago and apparently others have asked about this too. I wondered if it was possible to select the transitions for RND mode.
Been catching up on this wonderful piece of software a lot these last few days and am starting to figure out just how far I can go to control Resolume with OSC. Mind = blown.
I'm a Processing afficionado so I decided to solve it that way. It runs on windows & OSX and the script is extremely simple to adjust. No need for programming knowledge. You can make a list of transitions, a list of the layers and whether they all have to be the same random trans.
I've written up instructions on how to do it here:
http://alexanderdudek.com/blog/selectin ... processing
Hope it helps!
Sadler
Re: RND transitions - I made a script that lets you select w
Post by Sadler »
No file exists when click on 'here' on your instructions on your site.
Perhaps post the script here?
alex_d
Post by alex_d »
Sadler
Post by Sadler »
Many thanks - works a treat and quite instructive for a start to more interesting controller experiments.
alex_d
Post by alex_d »
You're welcome! I've been learning from and using other people's scripts/tools for years now so it was about time I started contributing :)
I have some ideas in store for Resolume, will be interesting to see where it leads me.
