Mapping without videos with objects (future competitve)
Niflheim123
Post by Niflheim123 »
Hy,
wanted to tell you about a beta software http://www.heavym.fr/ that has some interesting mapping features like the option to create objects (square, round, triangle) that can be applied with effects.
Will this be a possible new option in resolume arena?
Thank you..
drazkers
Re: Mapping without videos with objects (future competitve)
Post by drazkers »
Always good to have more options!
Pretty sure you can just use current resolume effects to create everything in your video, want to go into my detail on what you offer that resolume doesn't? Do i spy some clips that i think was purchased off the resolume store :p
Good job on bringing a product to market. :)
Niflheim123
Well first of all is not my product :D so the credit goes to the developers.
Second, if you install the software you can see that it can create objects without movies in it that appear on the projection and you can add some effects to it (border width, rotation, fill color etc). That is an interesting and easy option to map objects, in my personal opinion.
my 2 cents :P
He2neg
Post by He2neg »
the video is nice,
and i also see the things done more easy then with resolume...
But maybe i didnt search good enough^^
~Berlin~
Niflheim123
Yep, that what I was talking about. A more easy and accessible shape mapping including without video.
DayVeeJay
Post by DayVeeJay »
It supports syphone and spout so you can use it with resolume
