Problem with 4.1.11 arena
Hye all, i dont know whether someone already highlighted this matter. Theres a problem with shortcut keyboard mapping in arena ver 4.1.11, for example. i Set the spacebar button for column 1, when i press the button resolume will back to the column 1 area..force me to scroll back to current column eg column no 100. Everytime.
Re: Problem with 4.1.11 arena
this is a feature.
in preferences /general, there is an option which enables automatic scrolling to the selected clip and layer.
try to disable that.
when you push space, column 1 becomes the current column. the active layer clip gets selected.
about keyboard mapping...
there is a default application key map with pre mapped keys, and you will be able to map these keys again in composition key map.
just be sure, not to map the same keys again, or you will see stuff happening which you didn't want.
Here is the list of the default application key map: http://resolume.com/manual/en/r4/keymap
You also have the option to [Remove All] and start with a new application keyboard map.
Great! thanks so much
