Copy input slice to output and other Adv. Output Features
DayVeeJay
Post by DayVeeJay »
So apparently I come up with 101 ideas when I'm working like crazy... I think it'd be pretty cool if you could press a button and the shape that you made on the input is copied to the output (and vice versa). I find that simple shapes are similar on the input/output screens a lot of the time. Even if they're not, it makes seeing your slice a lot easier when you switch.
Re: Copy input slice to output
Good call...just ran into this situation the last two days while mapping 56 little led panels.
+1
Merry Christmas
DayVeeJay
Post by DayVeeJay »
A snapping feature and the ability to do simple math in the size/position fields (such as 1024/4=width or 1024-256=position) would be really nice.
Now I'm starting to get excited about the future release of R5 :D :D :D
Re: Copy input slice to output and other Adv. Output Feature
DayVeeJay
Post by DayVeeJay »
Thanks Joris! I think I need a little refresher. Time to bust out the manual and tutorials.
