I am a Newbee in Resolume Arena. In the manual, there is mentioned a function called Layer Routing. And it seems to me, that this is not the Layer to slice function.
But there is no description inner the manual, how to use it, if this is not the same function. Probably there exist videos about the functions, but if there are videos inside the manual, I can not see them, no matter, which Browser I use. I see only empty placeholders.
However. I can not find the function. Can anybody tell me, where to find this function?
Thanks.
How to do Layer Routing
Re: How to do Layer Routing
If you look in my posts, you'll find several explanations on how to use the layer routers. Keep in mind there are many ways to skin that cat!
