Hello,
I've said it all in the title, I need and OFFLINE Flash Installer.
I set up myself a nice and clean XP SP1 installation dedicated to resolume and of course I don't want to set up internet on that install (because that would mean install the wireless network, install an AntiVirus, install a FireWall and then another thing and so on...)
So I can't do the f***ing Macromedia online Setup, I downladed an installer but it was only for Mozilla compatible Browsers and it isn't enough to make flash plays in resolume.
So if you know about that Internet Explorer offline installer or any other way to be able to read Flash Files please tell me.
By the way I already installed Shockwave but it isn't enough to play my flash files.
Need Flash Player OFFLINE Installer
no, it won't , (but thanks a lot for trying
) I tried the Netscape/Mozilla/FireFox installer (had to install FireFox...) and it work but... only for FireFox.
So I can see my flash files but only with FireFox, I get no preview in the explorer window and can't see them using IE so "Windows don't know flash yet" even if FireFox does.
Such a pain in the a** Macromedia doesn't offer a separate download for their plug in.
Someone else ?
I know this is a though one , I wouldn't be asking otherway.
Someone else ?
Found it (thanks to another great Forum) :
http://software-files.download.com/soft ... _winax.exe
works like a charm
[Edited on 21-12-2004 by Rincevent]
works like a charm
