i searched a bit in this forum and their FAQ bu nothing helpfull.
http://emaqdesign.com/video_loops_flash.html
i got their TextWriter Flash Plugin, it just says to load the .swf File in your Deck and start.
On my System the .swf File ist marked as broken ( Yellow X)
i read that the flash Problem should be done becouse resolume uses his own flash plugin in an olf .swf problem thread or am i wrong and i should install flash player 10. someting ?
In the Folder their are some other Files ( .as ) do i need to do something with them as well ?
System : Win 7 / 64bit / Resolume 4.1.11 / Flashplayer 16.00.3...
i hope it can be solved quick and easy
