Converting DXV program problems
Kadete
Post by Kadete »
Hello everyone!!
I'm trying to use MPEG Streamclip to convert my clips to DXV 3.0 codec, but the program keeps crashing/freezing after convert 15~30 clips... it's anoying having to add the clips and redifine the prefs over and over again...
I'm the only one having troubles with this program?
I also tryed to use the Adobe Media Encoder, but i can't find a option so the output resolution match the input... i only can set a output preset for all the clips (unscale on MPEG Streamclip). I'm blind? Where is the option?
Happy easter week
