1.1 Problems
jesse_
Post by jesse_ »
Installed 1.1 last night at a show and found it to be very buggy... I've got an ATI All-In-Wonder AGP 16 Meg card that I do TV out on and if I tried to maximize the screen, it wouldn't play the video, AND, part of it would overlap onto the second monitor blocking my controls. Second, the performance was horrible. Clips would not play at a speed that was even close to workable. Third, FX froze the program.
1.1 looks VERY cool but until I can get it to reliably work, I'm outa luck.
Any ideas?
flip_
Post by flip_ »
Hi Jesse
Try the following:
first select "dual monitor"
if you see something in the popup window,
choose "configure", the "output"
select your resolution (start with 320/240) and next
"Current Monitor" (this seems to be off by default)
Now switch to full screen
I hope this works in your case ...
and you did not have these problems with version 1.0?
perhaps the problem lies in how you set the output window fullscreen on the second output. 1.0 only maximized the window to the size of the second monitor ... 1.1 now changes the second monitor resolution to the output window ... this is a lot faster in most cases ... but you can still use the 1.0 method! just link the maximize button on the output window and not the fullscreen button ... hope this helps ... let us know!
jesse_
Post by jesse_ »
Even when I got it to full screen, the frame rates were soo ppor that I couldn't do anything with it.
:: jesse
