Hi there,
I've connected chamsys magicQ with my resolume via dmx and both computers seems to see each other and get comunication, the problem is when I try to trigger a clip from magicq, the clip is selected but it doesnt play,
Anyone knows what Im doing wrong?
Many thanks in advence
Q.
Triggering probs
Re: Triggering probs
Assuming you're using the DMX Auto Map feature, what DMX channel(s) and value(s) are you using to trigger your clip(s)?
Hi there, thanks for your answer!Oaktown wrote:Assuming you're using the DMX Auto Map feature, what DMX channel(s) and value(s) are you using to trigger your clip(s)?
Yes DMX auto map is selected
i cannot tell you about channels/levels cos right now Im not in front of the system but whatever channel chamsys gives to composicion plus layer 1, and I guess they should be at full... Would this be ok?
Cheers!!
Is it not playing because the layer playback is paused or is the clip just selected and not triggered?
Personally I just mapped out my own layout in the exec page with generica dimmers. Without CITP i've always found the media server control of chamsys to be pretty wonky and prone to serious fuckery across all media servers.
I've recently had the MQ40 out just to control resolume and touch designer. Its a great little setup.
