APC Mini Midi Feedback
Ollyman2
Post by Ollyman2 »
Bought an APC Mini recently to use with Arena, has anyone had any luck with getting it to work properly with the Midi Feedback? I.e. getting the green, amber and red lights to work other than just a green light to indicate you've selected a clip? Can't seem to find anything to change it....
I've had a quick look through the XML file but there's nothing in there that seems to indicate it can be changed
Cheers! :-)
drazkers
Re: APC Mini Midi Feedback
Post by drazkers »
I've always had to use Bomes for the apc line.
Ollyman2
Post by Ollyman2 »
Ah fair enough, is there anywhere to teach you how to use it? Probably a stupid question but I don't know Midi very well unfortunately...
Talk to Sleepytom, he did some work on the APC Mini using Processing recently: viewtopic.php?f=7&t=11851&p=48535#p48535
