midi & column
rescs
midi & column
Post by rescs »
Sorry for my english!
I don't understand, after a midi map it's possible to send a command play in a column but a clic in the column not send a midi info ?
Please, is bug? a forget comand or it's me ?
Thanks for your reply
The osc also is strange withe the column target
Nice day
Re: midi & column
To be honest, I'm not completely sure if this is a bug or desired behaviour. A column cannot be 'active', so the led feedback would only be momentary. It can be argued that it shouldn't output at all.
But I'll make a ticket for Bart to make a decision on it. It would help if you could describe why you would like to have led feedback on column mouse clicks.
Osc output is working as expected. Resolume consistently outputs '/trackX/connect 1' when column X is triggered.
rescs
Re: midi & column
Post by rescs »
thanks,
i need the same as clip auto pilot " triger next clip" for a big difficult show, but with column. I make a patch in a other software for this, but with a midi protocole, i've not a triger and with osc "in my computers" i've make test with 3 desktop arena receive '/trackX/connect 1' but he send with a column empty '/trackX/select 1' and nothing with a column with clip ?? only the clip and layer osc message ??
He2neg
Re: midi & column
Post by He2neg »
you will find it here :
viewtopic.php?f=6&t=9478
~Berlin~
rescs
Re: midi & column
Post by rescs »
He's not a good way for me, perhaps the division pixel program but i have a PC platform.
So, i've make lot of test with many OSC listener and if the column receive each time the osc the send is really not sure.
