new laptop
Hubotron
new laptop
Post by Hubotron »
Hi everybody!
I'm buying a new laptop for vj gigs and i'm not quite a computer geek so any help would be usefull.
For the price of 1200 euros and resolume composition with blend masks with 3 or 4 layers and bunch of clips, with two outputs, whats the best-
1. cpu/gpu?
2. graphic card
3. RAM
Also, what else do I need to look for so the Resolume, Adobe and Cinema 4D can run smooth?
For now, i'm looking gaming laptops, i gues they have stronger insides :)
Thank u guys!
And yes, i'm not buyin mac
He2neg
Re: new laptop
Post by He2neg »
Here you can see how different Laptops behave:
viewtopic.php?f=11&t=11093
GPU is the most importend part for Resolume :roll:
but dont lose sight of the HDD/ SSD for smooth playback.
Since Resolume is a 32bit application you dont need to upgrade your ram to infinity :geek:
I can recommend the Schenker Manufacture for good Service, solid machines and the option to Custom build your Laptop. http://www.mysn.eu/
~Berlin~
AdevProjects
Re: new laptop
Post by AdevProjects »
Getting an ssd really helps both composition+clip load times and playback smoothness. I would recommend getting more than 4GB of ram perhaps 6-8GB to allow resolume to use the full 3ish GB (32bit limit) of ram if needed. Some form of (probably mini) display port output is useful for connecting multiple screens through MST hubs. For GPUs stay away from intel integrated graphics (seems youre looking for a gaming laptop anyway without this). Having at least 3 usb ports is useful for connecting midi controllers / computer mice / external drives in the future.
Re: new laptop
Hubotron wrote:Also, what else do I need to look for so the Resolume, Adobe and Cinema 4D can run smooth?
I realize Resolume is currently a 32-bit software but I have a feeling it'll be 64-bit before your new laptop is obsolete so plan for the future. Also if you plan to use the Adobe CC suite (assuming After Effect) and Cinema 4D and want them to run fast and smooth, you'll want a laptop with a good CPU, lots of RAM, SSD drive and a great GPU or you'll end up spending most of your time watching your computer render!
So, my recommendation to you would be to buy the best laptop you can afford and based on what you're describing I'm afraid 1,200 euros might be on the low end of the spectrum.
I would make sure get at least the following specs:
  • 15" screen
    high-end Core i7 CPU
    16GB RAM minimum
    at least 512GB SSD but I would personally shoot for 1TB
    GPU with at least 2GB of RAM with 2 Display Port 1.2 outputs (or 1 DP/1 HDMI but 2 DP will give you more bandwidth)
    3 or 4 USB3 ports
    Gigabit Ethernet
    801.11 ac WIFI
and here is the add'l list of things I personally like on this type of laptop:
  • Thunderbolt 2
    Retina display
    GPU with 4GB of RAM
    keyboard that lights up for dark venues
    No onboard DVD drive because they take too much space
Note: I know Thunderbolt 2 is more of an Apple feature but it's Intel technology and it's becoming more readily available on PC's so it's always at the top of my list because it gives you access to so many options and you can easily expand your system with capture cards, RAID drives, PCIe drives, add'l USB3 ports, Firewire, Ethernet etc... I have several Thunderbolt chassis that I can easily daisy chain depending on the project and I love it. For instance, I'll often use an OWC Mercury Helios chassis with either two BMD capture cards (1 decklink studio and 1 decklink duo) or 1 BMD capture card and 1 PCIe SSD blade (OWC Accelsior 256GB) , one OWC Thunderbay 4 with four 256GB SSD drives in RAID 1+0, and one OWC Thunderbolt 2 Dock and I can still drive a 4K video processing unit such as a Datapath X4 from the displayport output of the last Thunderbolt unit.
Brij
Re: new laptop
Post by Brij »
There are some options available to buy within $1000 which will let you do almost any kind of works. You should search google for that.
