MST: Club3d 1-4 MST HUB
AdevProjects
Post by AdevProjects »
I have recently bought a Club3d 1-4 Displayport MST Hub. Works well as described in the specs. I have had no issues with it. Just letting you know in case you were thinking of using one. Would recommend it if you need an mst hub.
chenthemagician
Re: MST: Club3d 1-4 MST HUB
Post by chenthemagician »
How many outputs and at what resolution have you been able to accomplish so far ?
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Livid OHM RGB Controller
Creating Solutions, Tailored to your needs!
Repping from the 876 - Jamaica "Out of Many, One People"
AdevProjects
Tested with 4 1080p displays plugged in with no problems.
chenthemagician
Awesome, which videocard are you running with it?
I have a 860m, and thinking that i may max out at 3
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Any GPU that has DisplayPort 1.2 (17.28 Gbit/s) should support a processor with four 1920x1080@60Hz outputs which is 3840x2160@60Hz (12.54 Gbit/s) divided in 4 quarters. And in theory, DisplayPort 1.1 would be able to support four 1920x1080@30Hz but I don't think it's an option with that unit.
AdevProjects
Ive ran it with 4 output nvidia gtx 760 and a 6 output amd 7970.
chenthemagician
Awesome, I'm working on a server interface, when I'm done I'll give you guys a look.
Respect
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
sssslamin
Post by sssslamin »
curious if this works with nvidia m graphics cards such as 970m 980m.
could a laptop with one dp1.2 one hdmi and one vga be used with this to run 6 displays plus the laptop display?
could a laptop with two dp1.2s use two of these and the built in display?
very curious anyone tested please report thanks.
sssslamin wrote:curious if this works with nvidia m graphics cards such as 970m 980m.
Yes but you'll still be limited to the 4 max displays including your laptop UI
No. Nvidia GPUs will be capped at 4 and AMD GPUs at 6 but not all cards will support maximum outputs.
No
Even though MST Hubs are very attractive on paper, I don't believe they are yet very reliable and I would never use them for a show.
MST allows to carry multiple streams on one cable but the GPU still treats it as as multiple displays so whatever maximum count your GPU has still applies.
In comparison, a video processor such as a Datapath X4 or a Matrox 2x/3x splits one large outputs into smaller sections so as long as your GPU supports the larger resolution, it's counted as one output.
For instance, I run up to 8 displays off my laptop (MacBook Pro) regularly using 2 Datapath X4 off the two MiniDP ports and I do multi-projector blends. I could technically run 12 displays by adding one more Datapath X4 off the HDMI port.
daan.hzndnk
Post by daan.hzndnk »
I have some experience with the MST-hub.
In my opinion, they're not working very stable. I used it in a permanent installation. From time to time (months) I got an call about something strange happening. It always was the MST-hub.
Maybe for very budget installations, it can be a solution. Otherwise, as said, the Datapath X4 is the best.
