LED brightness driver support
dirtyjohn_lv
Post by dirtyjohn_lv »
Built in support for brightness of common LED systems would be nice, instead of having to open the LED manager.
chenthemagician
Re: LED brightness driver support
Post by chenthemagician »
I would agree, however, why not have full midi/osc/keyboard shortcut control on the parameters on the slice, inclusive of brightness and contrast, X/Y/Z space, Size.
This would make for a better feature set than LED driver support which will then put Resolume team, under much stress to support a third party function.
my 2 cents from sunny JA
Chen
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
Livid OHM RGB Controller
Creating Solutions, Tailored to your needs!
Repping from the 876 - Jamaica "Out of Many, One People"
How's about we start with a list of common LED systems?
drazkers
Post by drazkers »
Quan zi province number 4 special 3.94mm(October edition!)
Hehe....I think I know what joris want to show us. There is no "common" LED System when you work as a Vj (-;
dirtyjohn_lv wrote:Built in support for brightness of common LED systems would be nice, instead of having to open the LED manager.
There are luminosity adjustment controls for each slice in the advanced output, are they not working for what you need?
chenthemagician
LOL....yup @cosmowe, I agree...
@ravensc, I was wondering about that
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
dirtyjohn_lv
Quan Zi
ZDEC
LINSN
I think there is a LOT of different chinese brands that use same driver system, 1 or 2 versions of FTDI drivers. They all use the same software to configure/control screens, they just change their user/password for the hidden mapping section.
I've even come across some non-Chinese brands using same driver system
@ravensc
I do use the brightness controls for some things, but still have to make adjustments to the actual LED controls themselves
Let's say I have my LED at 100% brightness for daytime use in both LED controls and Resolume. If I take Resolume brightness down to lowest value (half brightness) the LED is still to bright to use during night shows. I have to change my LED brightness to 10% in their control software in addition to taking Resolume brightness down.
Even something as having a choice as to if you want to link to LED controls would be nice
chenthemagician
What I have done in those instances was just to bring down the level of my master on the composition itself, and I'm good...i leave the brightness at 100% and have my master become the brightness control for me...less hassle than having to fiddle with LED software to handle the intensity level of the tiles....OR if needs be half the brightness from the advanced output then use my master....to give me a better overall output...this I have done to fix brightness and colour differences between the different types of tiles I have used on a single show.
My 2 cents from clear night sky in hot JA
HP Omen
8 GB RAM
i7 7th gen 2.8 GHz
Win 10 Home
Nvidia 1050 GTX
Asus G751J - 860M
i7 4710HQ 2.5 GHz
8 GB RAM
dirtyjohn_lv
Unfortunately I output to to 6 different screens in different areas of the venue that need different brightness levels. Might be adding more soon.
Not like it's hard to open the led control software for each screen, but with Resolume integration I can just switch a preset for the whole venue and I would be done. I just need a bigger usb hub :lol:
