Quick Tip: Hue Rotate and Hue Scale
Use Hue Rotate on your layers or on the composition to keep your colors in check.
Not only will your stage look better, your light guy will thank you as well. Sticking to 1 or 2 primary colors is the first step in working together with light and laser to create a better show.
