Hello,
first well done to Bart & Eddy for they top work with resolume 2, awesome !
But i'm having a sudden problem :
all my flash file won't play in resolume1.5, beta 2 and Resolume final 2.
although those files are playing fine with macromedia player and Flash MX.
has anyone had the same problem or would know what to do ?
thanks for your replies.
cheers
db
flash file won\'t play in resolume
thanks Levon,
it did the trick,
thanks again, you made my day !
[Edited on 4-1-2005 by DoofBoy]
it did the trick,
