The Dream Machine
chipukaz
The Dream Machine
Post by chipukaz »
Hello Guys. I'm trying to build my first media server console. I'm new in Resolum World. I normaly run my shows using Vista Spyder or Encore Systems. But this sounds more fun and less expensive to achive or create.
I ned to have at least 3 HDMI in, 4 SDI/SDI-HD in and 6 SDI/SDI-HD out. Need feed back about how powerful machine to get and the right capture and output cards to get. If any one can help.
mrfipe
Re: The Dream Machine
Post by mrfipe »
Hello,
You could simply do a good machine,
I use a
Motherboard Asus Dual Sk Z9PE-D8 WS with dual Xeon 2650 V2 it can handle 2 PCI 16x cards.
Dual SSD in RAID 0 for system and dual SSD RAID 0 for temp files (like the footage you will use in a venue)
I have two BlackMagic capture cards for dual input, you could use a 4 input HDSDI in one board version with some BMD mini converters, or some new BMD intensity extreme 4K.
For the output I use one GTX 970 and one GTX760 in a total of 7 usable outputs and 1 interface output.
To convert once again you could use BMD HDMI to SDI mini converters.
You could always use a better GTX with one or two matrox triple head DP edition. All this graphic cards use, DVI-I, HDMI or DP outputs, so easily you can get cables to HDMI.
Best regards
Filipe José Branco
3Media servers i7 860 8GB RAM 240GB SSD Nvidia 760
1Media server i7 7800X 16GB RAM 240GB SSD Nvidia 1080
1Media server dual Xeon E5 2650 V2 32GB RAM 240GB SSD Nvidia 1080 + 970
1MacBook Pro 15 Retina i7 16GB RAM 512GB SSD Nvidia 750
chipukaz
Post by chipukaz »
Mr.Filipe José Branco
Thank you for your help. Now I have a better idea where to go on the Build of the Dream Machine.
Best Regards
Carlos Camarena
