If you create a quartz composition with the stock "Line" patch, the line appears in the quartz composer viewer. But if you import the composition into Resolume, you don't see a line.
A quick Google search reveals that this is a long standing bug with Quartz Composer (I'd post a link to an example URL, but the forum software isn't letting me...).
I'm having trouble finding a working alternative line patch. I downloaded the Kineme GL Tools patches, but I'm seeing the exact same problem with the GL Line patch on OS X 10.10; the line appears in QC, but not in Resolume.
Does anyone know of a working alternative? It seems totally ridiculous to me that I can't even draw a line with Quartz Composer + Resolume (although I realize it's not Resolume's fault).
Thanks.
Quartz composition with line patch does not render line
alexmiller
alexmiller
Re: Quartz composition with line patch does not render line
Interestingly, the Kineme GL Line patch does work when I import a composition into VDMX, suggesting there might be a Resolume bug.
Scratchpole
There is another line renderer plugin floating around somewhere....
Search the Quartz Composer facebook group for more info.
