Hello Everyone! Im using resolume avenue 4! I really need you help on saving my cue points. When i set Cue points manually for a clip! It works perfectly! But after when i load the clip again after some time or later! the cue points which i made are blank again! i need to manually Cue everytime! Please suggest me to save cue point for clips?
2. Everytime i load any clip the output will be on zoomed resolution !! and i need to click scale to fit the compotion every single time to bring the output back to normal! Is there anyway where i can save the setting ?
Hey Joris, yes i tried saving the composition but when i reload the track or reopen resolume its already blank once again. All the saved cue points are blank once again. And Do you know how to make scaled output ? Thank you
When you save a composition, all clip settings, including scaling and cue points are saved. They will be there when you open the composition again.
Of course, when you create a new composition and import the clip again, these settings will be gone. Cue points and scaling are properties specific to how your clip is used in Resolume, not to the clip itself. So they are not saved in your file, but in Resolume.
Really, just save the composition with your clips scaled and with cue points set. When you close and re-open Resolume it will open the same composition again, with all clips as you set them.
