Would be nice if another level of save/load was available by being able to save and load a series of all 12 Deck Tabs.
This is a well known concept in the Live Entertainment industry where this feature is called a SNAP (=snapshot), and obviously saves the need to select the same set of multiple decks than dragging them to tabs for loading.
Regards,
GuyKo.
Save all 12 Deck Tabs in a single SNAP
Hi Guyko,
so you would like to have something like a project file.
wich will contain 8 decks (not 12).
there is a workaround, put all the decks wich you want to group in one category and double click the category in the deck list.
if you double click a category in the deck list the first 8 decks in that category will be loaded.
cheers
edwin
cheers
edwin
