Hi Eveyone,
I just upgraded to Resolume 5 and in my advanced output none of my presets are working. Anytime I go to load one it does nothing to the output. I really don't want to have to redraw some of mappings I have created.
R5 my screen prests are not working
- stagehand632
IATSE Stagehand Local 632
Barco Certified Multi Screen operation
Analog Way LiveCore Certified Expert Operator
Analog Way LivePremier Certified Expert Operator
Re: R5 my screen prests are not working
Yep same thing here, none seams to work.
You won't be able to import your screen presets from R4 into R5 so unfortunately you'll have to recreate your mappings from scratch but keep in mind the workflow is much faster in R5 advanced output.
Unfortunately, the coordinate system and rendering pipeline had to change so much on the new version, that it was not doable to convert old presets to the new system anymore.
