Q: best configuration for resolume
fool_
Post by fool_ »
Another question, I believed relevant:
can you indicate the best configuration for hardware and OS to run resolume?
and, moreover, can you tell us what codec and program to convert file you suggest? i know you say midvid, but so far I had no good result, using Virtual dub as converter...
thanx
ether_
Post by ether_ »
try
windows2000
320x240 ligos indeo 5.1 codec (free download)
90% quality
keyframe every frame
good luck
the most importand thing to consider when buying a new system is getting a fast dualhead videocard the new herculez radeon 8500 cards are superb ...
using the cinepak codec wil give the fastest playback results but the indeo codec will give a higher imgae quality ...
daniel_
Post by daniel_ »
I just can confirm ligos indeo5.1. I´m using it on 100%quality and still running fast- specialy with the new beta2
cheers
