synchronization failure using 2 outputs video
FREDY-ARAUJO
Post by FREDY-ARAUJO »
I am using Resolume arena v4.1.11
retina MacPro machine
using an LED panel 3mm novact system
He2neg
Re: synchronization failure using 2 outputs video
Post by He2neg »
We cant help you if we cant understand what exactly is your problem.
Start again and tell us what is not working and what do you want to get...
~Berlin~
FREDY-ARAUJO
Resolume use the arena to join multi screen
when I finish the map and released the video in the union of the screen is giving a fault in the synchronization of video outputs
equipment used macbook pro retina 3 video outputs designed in a 3mm LED panel
FREDY-ARAUJO
My spends his email'll make a video and send it to you
Empyfree
Post by Empyfree »
If you're using three separate outputs of a MacBook Pro you must be using the HDMI socket. This does indeed usuall lag behind the other two (thunderbolt) output. The thunderbolt outputs are usually pretty close together. Best solution if you have one available is a triple head2go where you would just use a single output from your Mac. Everything stays in sync then. We have to do this to get the key/full feature to work.
