Encoding problems
Encoding problems
Hi there. I have some encoding problems with russian language, see the screenshot.
Re: Encoding problems
Have you tried setting the font to Arial Unicode?
Just tried this, nothing changed. I think this bug is deeper, than problems with font. For example, broken code page in Documents folder name, like I said in another thread.
Sorry, I must have missed your other post, I've made a ticket for saving files with cyrillic characters.
Problems with filenames are not related to text in the GUI though. Did you restart Resolume after toggling the Unicode font?
Yes, of course.
My another thread is viewtopic.php?f=12&t=12483. Maybe there is problems not only with cyrillic characters.
Just look at my screenshot in first post: text in highlighted area is broken, but selected slice at left displays right and non broken name "Тест" (try to copy-paste it).
Seems like "ÐÑивеÑ" is Unicode string "Привет" in ISO8859-1 codepage, just look where you use ISO8859-1. Somewhere in ScreenSetup.dll
Just make video that describes problem. As you can see: when I click on resolume window after editing text, it modifies into wrong codepage, but if I click on explorer window (for example), text stays unmodified. Also non-english text is sadly non visible on slice.
Now it's all good with UI, but non-latin characters still doesn't render in preview. Just as in the video above, at now renders "!", not "Привет!". Even with "use Arial Unicode MS" enabled.
So with 'preview' you mean the name on the slice in the Advanced Output's stage, right? The name in the top right and left side are now both correct?
Yes, "preview" is name of slice on the stage.
And yes, there is no problems with encoding in the names on top left, and right.
