Increase transition time
Any reason why the transition times are limited to 10 seconds. I would love to be able to have much slower transitions using that built-in feature.
It'd be great if this feature could become a slider in the layer panel similar to the speed sliders when you use the timeline feature to animate parameters where 1=5 seconds (default), 0.2=25 seconds and 5=1 second to be consistent with all other parameters.
Ladin
Re: Increase transition time
Post by Ladin »
And please, please, put there some marker (or digits), that shows, how long the transition is.. I know that I can set up the transition duration by mapping keyboard, but it will be wonderfull to know, what I´m setting up by slider.. If I need to set up the same transition duration (or a little bit different) in all layers quickly, it is almost impossible..
