Is there any grafic card with multiple outs
Anonymous
Post by Anonymous »
As I understand Resolume can play video on multiple monitors.
I need at least 3 or 4 s-video or composite outs card...
Please tell me is there any card, that can make do it.
Thanx for your attention.
levon
Post by levon »
i dont know if there are any that have 3 or 4 Svideo outs but, you can use multiple video cards in one computer, one AGP and the other few PCI or PCIE.
edwin
Post by edwin »
i think matrox has a quad-head card.
we use an matrox-dualhead card and a pci card for testing.
that way we can have three displays.
we tested multi-monitor support a while back on another more brutal machine. it had an radeon dual-head agp card and an pci-express dual-head card. So we had four displays with two videocards.
If you can afford it, this would be the way to go. Pci cards are slow but pci-express is really fast (faster then agp). Though resolume will work fine with a normal pci card as well. Try to use the pci card for the interface and the agp card for displaying the output. That's for performance sake of course.
cheers
Edwin
Anonymous
Post by Anonymous »
if i by for example this computer: DELL InspironTM 5160... do i have to by a new graphics card or can i just install resolume2 and get dual head!?
(nVidia ® GeForce FX Go5200, 64 MB DDR-video memory, is in the computer from start...)
