Drop Shadow help
Supernova
Drop Shadow help
Post by Supernova »
Hey guys. Maybe some one can point me in the right direction? I downloaded the drop shadow dll file and loaded it into : (C)>Program Files (86)> Resolume Arena 5.0.0> plugins> vfx
I see drop shadow in my effects tab now. But it doesn't seem to be doing anything when I load it onto a clip.
Did I put it into the wrong location?
Re: Drop Shadow help
Supernova wrote:Hey guys. Maybe some one can point me in the right direction? I downloaded the drop shadow dll file and loaded it into : (C)>Program Files (86)> Resolume Arena 5.0.0> plugins> vfx
if you see it in the effects list, then it is loaded and ready to use.
if you have the layer blend at default: ADD at 50% you won't see the black shadow.
Supernova
Post by Supernova »
No I have the layer at 100%, but I see no affects of the effect. Any other ideas?
Is the drop shadow clip scaled smaller than your actual output + do you have some sort of background so that you are surly able to see the shadow?
Greetings
Have you made sure your clip has transparency?
