Its really awesome that Adobe Flash content can be displayed and manipulated in Resolume.
However, I find that for my purposes it is really cumbersome to have to go through resolume parameters to make manipulations in the flash animation, especially because I have a large array of parameters that change every 100ms or so. I noticed that if there are many parameters and they change a lot, then resolume slows down to a halt. This problem would be completely solved if resolume would allow importing swf files that are published with target 'AIR for Desktop' within Adobe Flash, instead of target 'Flash Player'.
In this case, I could implement UDP datagram socket listeners directly inside swf and would not have to go through resolume interface.
Any hope for this some time soon????
I'd be sooo happy, i can't tell you.
osc communication with flash content
Re: osc communication with flash content
Sorry, we're not going to add functionality to the Flash implementation anymore.
