Hello,
I have an other issue with controlling Arena 5.0 using DMX (thru a Enttec USB-DMX Pro),
this time on AV Faders and A-B Faders not sticking to it.
When the "AV Fader" DMX value of any layer goes "cut" (not fading) to any other value than 0% or 100%,
the AV fader moves but the A and B faders don't follow and the intensity of the layer is not changed.
If you cut to 0% or 100% : all works nicely,
If you fade slowly to any value : it works nicely,
It's when you "cut" to a value different to 0% or 100% that the problem appears.
In my case, DMX is generated by a GrandMA2 using the Layer Fixture for Arena 4.0 (witch have the same DMX chart than Resolume 5.0)
Resolume Arena 5.0 running on a Mac Pro (end 2013)
- Proc : 3,7 GHz Quad-Core Intel Xeon E5
- RAM : 12 Go 1866 MHz DDR3 ECC
- GPU : AMD FirePro D300 2048 Mo
- SSD 250 Go
- 3 DVI output FullHD
									AV Slider Bug
AV Slider Bug
Video tech on tour - Catalyst, Resolume Arena, VVVV and MadMapper professional user.
						Re: AV Slider Bug
We've recreated this issue and made a ticket for it. Thanks for letting us know about it.
