Last night I was VJing with a 1280x480 composition,
meanwhile recording with Syphon Recorder, using advanced output to projector.
at most 20 clips in each decks,
almost all clips are DXV3 codec, only 9 clips are DXV2.2.
At the same time the cleaning app Dr. Cleaner is on, I was wondering if I should turn it off when VJing.
When opening 3 or 4 layers, toggling AB fader and fast changing clips of layer1 and layer2,
Resolume suddenly shut down and last night it shut down 2 times!
However NOT every time when I do this it will crash!
Today I tried many times with the same setup, it shut down only once.
Please check the attached photo. It seems that my memory is still enough?
I will have a gig the day after tomorrow and I am worried.
Thank you for any help!
I use Macbook pro
OS X Yosemite 10.10.3
CPU:2.8 GHz Intel Core i5
16GB 1600 MHz DDR3
Intel Iris 1536 MB
