I am trying to link two computers running Resolume Arena 4.  The laptop is the master, and the pc is the slave.  I am following the instructions in this thread: viewtopic.php?t=9578
The instructions seem very simple but in practice this is not working.  The slave machine gives no indication it is receiving any signals.  The machines are on the same network, firewall is disabled.  I have no problems accessing each over the network and copying files over, but no communication between the two instances of Resolume.  What did I miss?  Can anyone here help me troubleshoot this issue?
						Syncing Resolume on 2 machines via OSC
Re: Syncing Resolume on 2 machines via OSC
The only thing that's missing in that post is that you need to set the [Send to address] to the IP address of the slave computer. By default, it's set to 127.0.01 which is a loopback IP address  (Localhost) so unless you change that address the master is talking back to itself rather than sending OSC messages to the slave.
