V4 And V5
rayrayray
V4 And V5
Post by rayrayray »
Hi
Is it possible that Resolume Arena Version 4 and Version 5 can be installed in the same MacPro?Will it conflict the Arena if do so?
Ray
Re: V4 And V5
the can be installed both without problems, just don't overwrite compositions you intend to use in R4 from R5 .
R5 makes a copy of them if you choose to, you can use the copy in R5 fine.
Re: V4 And V5
Yes, you can run both versions concurrently on your computer but they cannot share outputs. What are you trying to do?
rayrayray
Re: V4 And V5
Post by rayrayray »
Thankyou
Re: V4 And V5
On your mac, you can actually feed one into the other using Syphon.
