Blank Preview Windows
I am a new user of rev 2.8. After saving several decks, when I try to reload them the channel windows are blank (white) but the decks play ok. One deck had the wrong images in the channel windows. Anyone had this experience? Solution? Thanks.
Hi there.
I have a similar problem. I managed to get Resolume 2 working last week. Since then I managed to break it - probably by installing a new driver fro my radeon 8500DV.
So I wiped my XP Pro install and have a clean build.
With the default drivers I have installed Resolume 2 again and get no video display in the deck screen or on dual screen.
I have installed a number of updated drivers for the Catalyst and none of them seem to work.
I have re-installed resolume 1 and that shows video.
This is driving me nuts. Just wiped my machine again incase there was some driver confusion but no avail.
I get the same as the poster above with no displays showing until I apply 16bit colour depth...
Hi again. Me in the above post. I can't seem to login as Paradine....
Anyway. Have downloaded 2.1 and installed it with other (possilby related)
2.1 seems to have a bug so that I can change drives and I can't drag anything across to the decks.
Oh well.
Could this display issues be related to Codecs? Or does the favt that it displays in Res 1.x mena that the codecs are ok?
Anyone have any thoughts for Radeon 8500DV... someone must be using this? If so which drivers please?
Oh well.
