does anyone know if i can control the Edirol V-4 Video Mixer inputs via midi not mixing from A to B but choosing which input source from 1 to 4. on the V - 1 you can ive read the manual but the V-4 manual doesnt say if it does;)
hello.
im at work at the moment,so i cant test this out but...
bpm button - i use an audio to midi clock convertor,and the v4 tempo changes accordingly - so you can control it with midi clock:) - realy nice knowing you can just turn on an auto mix/wipe/fx and it will be in time:)
memory - not sure,as i dont use this under midi ( i prefer to change on the fly) but looking at a copy of the manual on-line,i see it can accept program change messages,so it should be just like changing presets on a synth...just transmit a new program number to change memory preset.
i'll check this when i get home for you:)
