SDI output format change - crash
thomasl
Post by thomasl »
Greetings,
I m runnig configuration with mixed DVI out over Nvidia and SDI over Blackmagic card.
In my set up is used DUO card - one chanel input , next chanel output.
When I set output screen for BMD it has default setting for 1080 p30. When I want to change output format, Resolume (5.0.1) crash.
System with W7 64bit with last drivers...
Re: SDI output format change - crash
Could you use the Feedback tab in the preferences to send us your log file, please?
thomasl
Post by thomasl »
Ok.
