Hi..Guys
Need Urgent Help... I have got two Black Magic Cards but only one card is working.
1. Black magic intensity pro Card - ( Capturing Fine)
2. Decklink mini recorder Card - New Card Add to the system Card Detected but Not Working
Please help us with this Issue....?
Black Magic Two input Capture not Conneting
Re: Black Magic Two input Capture not Conneting
Have you tested your other card with Blackmagic Media Express to make sure it works?
I have (insinity pro) checked it with resolume working fine.
but mini recorder showing but not capturing any thing
I have (insinity pro) checked it with resolume working fine.Oaktown wrote:Have you tested your other card with Blackmagic Media Express to make sure it works?
Test it with Blackmagic Media Express to make sure it's working.
Obed wrote:I have (insinity pro) checked it with resolume working fine.Oaktown wrote:Have you tested your other card with Blackmagic Media Express to make sure it works?
it dose not show's up on media express .**** but insinity pro works fine in Blackmagic Media Express
It sound like you may have some hardware issue then. Is you mini recorder a PCIe model?
1-Lane PCIe Slot Capture CardOaktown wrote:It sound like you may have some hardware issue then. Is you mini recorder a PCIe model?
have you tried switching your two cards to see if it's the card or the lane?
