MSI Laptop freeze when second output is activated
hive8
Post by hive8 »
Hi I just got a new MSI Laptop i7 6700, 16GB Ram, 256 GB SSD NVEM with a GTX 970 3GB. When i start resolume by itself it works great. As soon i want to output something to Display 2 or advanced output resolume freezes.
I tried advanced output and fullframe window, same behavior. Anyone has a solution for that.
The laptop sees the second output and i can configure it as a extended screen with a resolution of 1920 x 1080
I set the windows settings to no scaling.
I changed the audio settings to 1024 buffer and 48hHz, not sure if that does anything.
Nvidea Drivers are 362.00 and the intel 530 driver are updated to newest version. In the Nvidia panel i set resolume app to high performance only. Both displays are set to a scaling of 100%.
Any help would be appreciated, would like to use the laptop this weekend for a show.
